Pietenpol-List: Hotel Key Cards
This morning I forwarded an E-mail that said motel key cards held some personal information that could be misused. Later I discovered that Snopes denies that this is true. Snopes sometimes is wrong. I'll let you be the judge as to the veracity of the information. Sorry if this has caused some ill will. Chuck________________________________________________________________________________
RE: Pietenpol-List: Hotel Key Cards
Charles,No apology should be necessary.err on the side of caution..don't trustSnopes..and..LOCK YOUR FRIGGIN' DOOR WHEN YOUR INSIDE!!Just to make this Piet-related.a hotel robbery cost me at least 2 monthsworth of progress on my project.Gary
Pietenpol-List: Re: Two Part Post- need help in SE Ohio looking at a fuselage
I test the accuracy of my airspeed instrument by using a similar Pitot tube ina car speed check at all speeds, when there is no wind and a two direction run.3 feet away from the car will be close to perfect.And mark stall, cruise & notto exceed, for face references.Pieti LowellRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Two Part Post- need help in SE Ohio looking at a fuselage
