Original Posted By: "Chris Rusch"
Oh ya Dale,I was definitely thinking of flying back up or inviting you down (or both). Iflew over some really neat little field (I think I "tagged" it with my GPS) abouthalf way that is a base for hunting lodges or something. That might be prettycool.The Piet really draws a lot of attention where ever it goes, that was a lot offun as well.ToolsRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Push Pull Elevator?
I am wondering if anyone has detailed pictures of the "BIg" Piets push pull elevatorsetups? i saw them at EAA and would like to study the design. The piet iam finishing has a push pull set up already in it, i would just like to comparethe designs. Also, has anyone run the rudder control horn below the elevatorto give a more straight line to the rudder bar? Again mine is already builtthat way and it seems to me there will be allot of twisting action of the rudderif not mounted centered. Thanks in advance!ChrisRead this topic online here:http://forums.matronics.com/viewtopic.p ... __________
RE: Pietenpol-List: Holes in helmet box
Hi Dan,Those are just vent holes to allow moisture to dry out.Jack PhillipsNX899JPSmith Mountain Lake, Virginia _____
RE: Pietenpol-List: Push Pull Elevator?
I'll send you some picturesBarryBig PietNX973BP -----Original Message-----
Pietenpol-List: Re: Push Pull Elevator?
Chris,When it comes to the Pietenpol, just about EVERY idea has been tried at least once- well, except some of Michael Perez's ideas...
. Just kidding, Michael.The lowered rudder horn is one of the modifications commonly done in the UK. Inorder to compensate for the torsion imposed on the rudder, the structure getsbeefed up, as indicated in the attached, poor image quality sketch.Bill C.Read this topic online here:http://forums.matronics.com/viewtopic.p ... ttachments: http://forums.matronics.com//files/rudd ... __________
Re: Pietenpol-List: Push Pull Elevator?
Chris, the GN-1 plans show the rudder horn below the elevators but the bottom of the rudder is beefed up pretty well. Pobably adds a bit of weight but I think it's worth it-- I'm doing my rudder that way. I just don't like the looks of the rudder cables going up above the stab/elev. C----- Original Message -----
Original Posted By: Jim Ash
Thanks for all the replies!Barry, i am looking forward to seeing your pictures, thanks.I just applied to the UK piet club, they said i can download there revisions onceim a member. They have the lower rudder horn revision as shown above.Does anyone have the elevator loads in lbs?Read this topic online here:http://forums.matronics.com/viewtopic.p ... ______Date: Tue, 18 Oct 2011 12:36:19 -0400 (GMT-04:00)
Pietenpol-List: Re: cool video
Great Job Douwe!Read this topic online here:http://forums.matronics.com/viewtopic.p ... __________
RE: Pietenpol-List: Re: Push Pull Elevator?
I looked, but did not locate all the pictures I am looking for. I only haveabout 15,000 to go through. I might go out to the airport and take some newones, but am leaving for New Orleans in a couple of hours. I'll have to doit when I get backBarry -----Original Message-----
