Original Posted By: Andrew Eldredge
Here is mine, compass goes in the top center hole. Slip indicator goes on the bottomcenter.Read this topic online here:http://forums.matronics.com/viewtopic.p ... ttachments: http://forums.matronics.com//files/img_ ... ______Date: Wed, 28 Mar 2012 14:32:01 -0600Subject: Re: Pietenpol-List: ignition noise when using radios (nothing about antennas--IPROMISE!)
I have an A-24 and an A-14. I like them both. I use the A-14 more because it is very small and simple to use. I velcro it to the inside of the fuselage. (FYI, JoAnn Fabrics has a great supply of Velcro in sheets and rolls. I also Velcro my iPhone to the instrument panel for navigation and when necessary, attach an intercom next to the radio.) However the A-24 came with the headset adapter and when I bought my A-14 it did not. When I purchased another of those the price was approaching what I paid for the A-24. -john-John HofmannVice-President, Information TechnologyThe Rees Group, Inc.2424 American LaneMadison, WI 53704Phone: 608.443.2468 ext 150Fax: 608.443.2474Email: jhofmann(at)reesgroupinc.comOn Mar 28, 2012, at 3:32 PM, Andrew Eldredge wrote:> Are your p-leads shielded? I've encountered the "buzz" but performance is still marginal even with shielded ignition wires. I'm looking at using shielded leads to see if that can get me into an operable situation.> > Andrew> > On Wed, Mar 28, 2012 at 10:45 AM, Cuy, Michael D. (GRC-RXD0)[ASRC AEROSPACE CORP] wrote:AEROSPACE CORP]" > > As long as we are talking radios, I use an Icom A-5 and it works> really well.> > I have unshielded wiring on my spark plug wires so the radio picks up> the 'buzz' noise of the engine firing.> > An old trick my Champ buddy Joe Tomasic told me wayyyy back was to switch> to one mag and throttle back some when wanting to listen or transmit as it> cuts the plug noise in half.> > Have used that method for years and years--works fine.> > Mike C.> > > > > > ==========> st" target="_blank">http://www.matronics.com/Navigator?Pietenpol-List> ==========> http://forums.matronics.com> ==========> le, List Admin.> ="_blank">http://www.matronics.com/contribution> ==========> > > > > > > -- > Andrew Eldredge> Provo, UT> > > > ________________________________________________________________________________Date: Wed, 28 Mar 2012 14:40:24 -0700 (PDT)
RE: Pietenpol-List: Fuel Tank Finished
Looks great Michael...... beautiful welding job!BrianSLC-UT
Re: Pietenpol-List: Fuel Tank Finished
Original Posted By: airlion
Nice Job. Any chance you'll be sharing the plans or will they be in the next video?RyanSent from my iPhoneOn Mar 28, 2012, at 5:40 PM, Michael Perez wrote:> Attached are pictures of my finished fuel tank. With the help of a friend, we fabricated the tank out of .032" 5052 aluminum. Another post of mine includes pictures showing the tank baffles inside. The tank was welded and pressure tested to about 3 PSI by Greg Klemp, who was mentioned in the first BPA newsletter this year.> > The tank as pictured with filler neck, cap and finger strainer weighs 6.5lbs. Next I will find out how many gallons it will hold and start the install. and fuel line hook-up.> > Michael Perez> Karetaker Aero> www.karetakeraero.com> > ________________________________________________________________________________Date: Wed, 28 Mar 2012 17:01:28 -0700 (PDT)
