Pietenpol-List: Re: Cable guides
Original Posted By: woodflier(at)aol.com
Congratulations, Jerry! Ain't that a terrific feeling. I had the same problem last year whenI got my airworthiness. It was pouring rain during the inspection and I couldn't do the first flight for several days. It was worth the wait. Can't wait to hear how it goes. Matt PaxtonNX629MLThe DAR came and certified my Pietenpol this morning. The weather is not cooperating.The forecasts look like it will be Saturday at least before this windylow passes out of here. Lots of covers to put on before then any way.--------Jerry Dotson59 Daniel Johnson RdBaker, FL 32531________________________________________________________________________________Subject: Pietenpol-List: Re: Cable guides
Original Posted By: "Ralph"
My Technical Adviser said I needed cable guides on all pulleys where the cable turned morethan a few degrees. I installed a bunch of them. The consequence of a jammed control cable is not one I care to consider. I used pulleys for the bend the aileron cables make at the back seat and they all got cable guards there also. Matt PaxtonNX629ML
Pietenpol-List: Re: Hegy prop; engine offset washers
Thanks for the reply Oscar. That prop works very well with my C-85 on my Piet.--------Scott LiefeldFlying N11MS since March 1972Steel TubeC-85-12Wire WheelsBrodhead in 1996Read this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Hegy prop; engine offset washers
Pietenpol-List: Re: NX510JD IS FLIGHT READY
Gary,I am looking forward to next year. My wife had family show up from Florida soI needed to stay behind this year. It looks like you had good weather which makesme feel that much worse about not going.--------Scott LiefeldFlying N11MS since March 1972Steel TubeC-85-12Wire WheelsBrodhead in 1996Read this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: NX510JD IS FLIGHT READY
Great stuff Jerry - Congrats.......!!--------Jake Schultz - curator,Newport Way Air Museum (OK, it's just my home)Read this topic online here:http://forums.matronics.com/viewtopic.p ... ______Date: Wed, 6 Jun 2012 09:44:42 -0700 (PDT)
