Im about to place an order for AN Bolts from the USA to Australia and have huntedthrough the archives and found we need a selection of AN3 and AN4 bolts butis there a need for AN5?With the cost of freight between there and here I thought doing one order wouldbe more cost effective. I dont have the plans in front of me right now and thoughtthose of you who have assembled their Piets may be able to chirp in here.Regards Scotty--------Tamworth, AustraliaBuilding a Corvair Powered Pietenpol Air Camperwww.scottyspietenpol.comTail and Ribs built...Building control system and about to start fuselage...Corvairengine at Roy's Garage waiting to be modified.Read this topic online here:http://forums.matronics.com/viewtopic.p ... __________
Pietenpol-List: AN5 Bolts on a Piet?
RE: Pietenpol-List: AN5 Bolts on a Piet?
Scotty,AN5's on both ends of the wing struts.Gary BootheNX308MB-----Original Message-----
Pietenpol-List: Re: AN5 Bolts on a Piet?
All,Susan and I are looking forward to hosting another lunch this year atBrodhead. We will be serving Friday at 11:30. Bring your own chair andbeverage. We will be located on the SE corner of the field, drive incamping area, green and white Itasca 37' coach. Susan's RED EzGo will beparked close by. Come and have some fun!Jack TextorDSMNX1929T________________________________________________________________________________Subject: Pietenpol-List: Re: AN5 Bolts on a Piet?
Original Posted By: "l.morlock"
Thankyou!...looks like a selection of AN3,4 & 5 will be in order!--------Tamworth, AustraliaBuilding a Corvair Powered Pietenpol Air Camperwww.scottyspietenpol.comTail and Ribs built...Building control system and about to start fuselage...Corvairengine at Roy's Garage waiting to be modified.Read this topic online here:http://forums.matronics.com/viewtopic.p ... __________
Pietenpol-List: Re: Straight Axle Stops
It is a Dan Price high compression head with two spark plugs per cylinder. I'm not sure of the compression ratio, as it came with the engine when I bought it from Douwe. Larry----- Original Message -----
Original Posted By: "Ken Bickers"
Ken and Oscar, thanks for the info and pictures on the Dilatush set-up. I'm sure this would work, but it looks much more involved than the arrangement I'm planning to use with a tether cable from the rear gear leg to the brake caliper. Seems like the latter fits my KISS philosophy better (Keep It Simple, Stupid). Larry----- Original Message -----
