Subject: Pietenpol-List: SonexSomebody better tell Sonex about these dangerous piano hinges....[cid:image001.png(at)01CD74C3.B597C680]________________________________________________________________________________
Pietenpol-List: Re: Sonex
As Billy Crystal would say " Kevin, you look MARVELOUS."Read this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Sonex
Those hinge-less ailerons work good. I did the phase one test flights on my friends601 HDS. My only complaint I had was that my arm would get tired if Idid too much pattern work in crosswinds. They are stiffer than most other planes.--------Scott LiefeldFlying N11MS since March 1972Steel TubeC-85-12Wire WheelsBrodhead in 1996Read this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Sonex
