Original Posted By: John Weber
Matt,You are amazing! Thanks! You did everything exactly as I would have! :-0Gary BootheNX308MBSent from my iPhoneOn Jul 18, 2013, at 11:38 AM, Matt Dralle wrote:> > > Dear Listers,> > A couple of weeks ago I found a web site on the Internet called LiveATC.net thathas the Air Traffic Control (ATC) tower communications on line for streamingfor a number of airports around the country. Lo 'n behold, they even havea stream for my home base, the Livermore Airport. But, much to my dismay, thequality of their KLVK feed was just plain awful. It was obvious the airbandsource didn't have a decent antenna or perhaps even a good radio. I suppose thatgiven that their site is a consortium of local citizens providing the feeds,the lack of quality goes with the territory.> > But, I really liked the idea of being able to monitor the LVK ATC and also theability to bring up the archives and listen to my personal communications withthe tower after a flight.> > Since I had a computer at the hangar along with a pretty decent Internet connectionand, in the spirit of Experimental Homebuilding, I had an idea... I mountedan air-band antenna on the top of the hangar and brought the RG-58 coaxdown to near the computer and plugged it into my trusty Icom IC-A20 hand held.I was AMAZED at the quality of signal I was getting. It was picking up guysin airplanes 19 miles out like they were sitting next to my hangar! I set theradio to high-speed scan between the Tower and Ground frequencies so with asingle feed I could get all communications.> > So next, I made an audio connection from the handheld to the Line In input on the computer. Sure enough, now I was getting great sound from the hand held on the computer! I found some software from Australia called BroadWave from a company called NCH ( http://www.nch.com.au/streaming ). It lets you connect to the Line In port on the computer and then generate real time audio streams that can be served up via the Internet. And sure enough, it works great!> > Next, I found some software from Germany called Loop Recorder ( http://looprecorder.de ) that let's you monitor an audio input on your computer and generate archive files. You can select an increment in which to rotate the files automatically, for example, every 30 minutes. I downloaded this software and installed it and sure enough, I was able to start archiving the ATC transmissions coming in, all the while streaming them live as well!> > The last piece of the puzzle was to enable the Web and FTP servers on the Windows7 system and come up with a front-end web page that would tie all of thesenew resources together for easy access from the Internet. I'm happy to report,the whole thing came together very nicely and even allows you stream directlyto your Android or iPhone as well as your desktop! Pretty darn cool!> > And so, without further ado, here is my new web site for monitoring the ATC communicationsat KLVK:> > http://klvk.matronics.com/ > > Just to state the obvious, the stream is silent if there isn't any current ATCor aircraft communications. During the day, you'll usually hear something withinfive or ten minutes. Sometimes much quicker.> > I contacted LiveATC.net and they were excited about adding my new stream to their web site as well. So, at some point soon, the LiveATC.net feed for Livermore Airport will be coming from my hangar! My site http://klvk.matronics.com will continue to be available as well.> > For entertainment purposes only!> > > > -> Matt Dralle> > RV-8 #82880 N998RV "Ruby Vixen"> http://www.mattsrv8.com - Matt's Complete RV-8 Construction Log> http://www.mattsrv8.com/Mishap - Landing Mishap Rebuild Log> http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel> Status: 172+ Hours TTSN - Rebuilding Fuselage After Landing Mishap...> > RV-6 #20916 N360EM "The Flyer"> http://www.mattsrv6.com - Matt's RV-6 Revitalization Log> Status: 170+ Hours Since Purchase - Upgrades Complete; Now In Full Flyer Mode> > Matt's Livermore Airport Live ATC Stream!> Check out the live ATC stream directly from my hangar at the Livermore> Airport. Includes both Tower and Ground transmissions. Archives too!> For entertainment purposes only. http://klvk.matronics.com> > > > > > ________________________________________________________________________________Subject: Pietenpol-List: EAA 534 Piet question
Re: Pietenpol-List: EAA 534 Piet question
Subject: Re: Pietenpol-List: EAA 534 Piet question
Pietenpol-List: Re: EAA 534 Piet question
smikewest(at)comcast.net wrote:> two quick questions,1)what carb are you using? 2)what inlet? ok, three, doesit have an accelerator pump?1) Model-B Zenith (Type 3), 2) not sure what you're asking (inlet) and 3) no, itdoesn't have an accelerator pump.Think I may have a solution though. Thanks for responding.Read this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: EAA 534 Piet question
