Pietenpol-List: Final trimmed tail post measurement
Original Posted By: "Pocono John"
Beautiful Piet Rick, mine is just about the same, 2700 cc Corvair, 17 gal frontcowl tank also designed starting from Mike Cuy's design (welded aluminum), 736lbs empty. Gravity feed to an MA3-SPA. Have a 66x30 Tennesse prop which givesme 3000 rpm full throttle level flight. 100 hrs TT and is a blast to fly (aslong as the temperature is 50 or above here in Colorado).Rick H--------Rick HollandNX6819ZRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Final trimmed tail post measurement
Pietenpol-List: Re: Final trimmed tail post measurement
Original Posted By: "aviken"
I just trimmed a tail post. It looks fine except one thing. My cut was measured1/2" from the inside, forgetting about the gusset. So that tail post is now .625wide, not .50 because of the gusset. If I do the same on the other half, mytail will be 1 1/4" wide, not 1".Is that a big deal? Is the tail post supposed to be 1" with or without the gussetsincluded?I can easy knock off another 1/8".just wondering. I can't seem to find it in theplans (probably right in front of me too).Thanks!John--------JohnRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Final trimmed tail post measurement
Pietenpol-List: Re: Corvair Piet performance report
Original Posted By: "Rick Schreiber"
I am not 100 percent sure but I believe the one inch is before the gusset . Mostof the measurements are of the frame work not the gussets.Read this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Corvair Piet performance report
