Pietenpol-List: Check out Kitplanes!
Original Posted By: Emelita W
Wow,Did you see the eight page spread on Piets! Haven't had time to read ityet, but is sure is impressive. About 8 pages. Definate addition to myfavorite issue pile!Stevee________________________________________________________________________________
Pietenpol-List: Re: Check out Kitplanes!
Original Posted By: peknow(at)midcoast.com.au (Peter Knowles)
Steve Eldredge wrote:> > Wow,> > Did you see the eight page spread on Piets! Haven't had time to read itGot it! Looking forward to sitting down in a quite corner and soaking up some "real culture"...Gary...________________________________________________________________________________
Original Posted By: Gary McArthur
>Wow,>>Did you see the eight page spread on Piets! Haven't had time to read it>yet, but is sure is impressive. About 8 pages. Definate addition to my>favorite issue pile!>>Stevee>>Which issue? Kitplanes doesn<t reach Australia for about two months. Inormally pick it up and thumb through it but put it down again if there isnothing that catches my interest.Regarding the direct drive Subaru. A friend is using one in a 7/8 scaleNeuport and the perfomance is very mediocre. That engine, which I shall beusing in my Piet, definitely needs a fairly low, as in ratio, reductiondrive in order to swing a 6 foot propeller of fairly course pitch (46"?) fortwo major reasons.(a) You need a large mass of air moving relatively slowly for a highdrag,low and slow aeroplane like the Piet and(b) The engine needs to run in the 3000 to 5000 rpm range which is where thetorque is, in order to drive that same propeller. The ratio I am using is 2.62:1Peter________________________________________________________________________________
Original Posted By: Dick Dery
Peter Knowles wrote:> > >Wow,> >> >Did you see the eight page spread on Piets! Haven't had time to read > reach Australia for about two months. I> normally pick it up and thumb through it but put it down again if It's the August issue. Real good article... Just when I thought aboutdoing away with my Kitplane subscription, I get a surprise! Guess I'llrenew for another year now...Gary...________________________________________________________________________________
Geez, our drugstores only carry the July issue so far. I'll have to snagsomebody with a subscription. (don't you love all the folks who visist your Piet project and want to know where you got your kit ?)OK- Fabric question: what's the treatment you used around controlhorn exits, etc. Did you PRE-shrink the fabric and tack it up witha coat of poly tak first and then glue it down or did you use the fabric'as is' and glue it down ? Thanks- mc________________________________________________________________________________
Michael D Cuy wrote:> Geez, our drugstores only carry the July issue so far. I'll have to>> snag> somebody with a subscription.>> (don't you love all the folks who visist your Piet project and want to>> know> where you got your kit ?)>> OK- Fabric question: what's the treatment you used around control> horn exits, etc. Did you PRE-shrink the fabric and tack it up with> a coat of poly tak first and then glue it down or did you use the> fabric> 'as is' and glue it down ? Thanks- mc On fabric. cover the part and shrink the fabric to 350 degrees. Thenmake a gussett of preshrunk fabric (225-250degrees) and apply withpolybrush. Let dry and do a second coat. One thing that really helpsis to apply the gusset in a bias to the protrusion. This makes theshrinking process much easier. After the second application of polybrush is dry, shrink evenly around the protrusion. I lapped the fabricup about 3/8" on the horn itself for better adhesion.Stevee________________________________________________________________________________
Original Posted By: "Craig R. Lawler"
Michael D Cuy wrote:> > Geez, our drugstores only carry the July issue so far. I'll have to snag> somebody with a subscription.> > (don't you love all the folks who visist your Piet project and want to know> where you got your kit ?)> > OK- Fabric question: what's the treatment you used around control> horn exits, etc. Did you PRE-shrink the fabric and tack it up with> a coat of poly tak first and then glue it down or did you use the fabric> 'as is' and glue it down ? Thanks- mcMy vote is to pre-shrink...Gary...________________________________________________________________________________
Original Posted By: D.BELLISSIMO(at)littonlsl.com (BELLISSIMO, DOMENIC)
Mike,I used the pre-shrink method and just glued it on with fabric cement.I was out in the Piet for about an Hour and a half last evening. It wasperfectly smooth. The only bumps were when I hit my own wake. The Pietis so much fun to fly I haven't been doing any cleaning or working on itand ect. just been flying a bunch around home. Your photo's look great.When do you think you'll be ready to fly?Craig________________________________________________________________________________
Original Posted By: mahal5(at)juno.com (Emily Williamson)
writes:Peter Knowles wrote: Wow,Did you see the eight page spread on Piets! Haven't had time to read reach Australia for about two months. I normally pick it up and thumb through it but put it down again if It's the August issue. Real good article... Just when I thought aboutdoing away with my Kitplane subscription, I get a surprise! Guess I'llrenew for another year now...Gary...I guess I really should, also. They do have me in there!JimV.________________________________________________________________________________
jimvan1(at)juno.com wrote:> > writes:> Peter Knowles wrote:> > Wow,> > Did you see the eight page spread on Piets! Haven't had time to> read> reach Australia for about two months. I> normally pick it up and thumb through it but put it down again if> > It's the August issue. Real good article... Just when I thought about> doing away with my Kitplane subscription, I get a surprise! Guess I'll> renew for another year now...> > Gary...> > I guess I really should, also. They do have me in there!> > JimV.Guess I would have gone out and emptied the rack if my project had beenincluded. It always renews the juices when mention is made of myfavorite plane, let alone a great article like this. Congratulations toall who were highlighted therein... :)Gary...________________________________________________________________________________
