Hello folks!
So I have been reviewing the plans for the Air Camper fuselage and a thought came to mind; has anyone ever installed adjustable seats in the AC? It would have to be on rails mounted to the base of the seat and then a new seat thrown on top but just not too sure where to start...
Adjustable seat
- Terry Hand
Re: Adjustable seat
Gary,
Do you plan on letting people fly your airplane a fair amount so that is why you need adjustability? If it is for you because of leg length you may be better of making a seat that fits you. The airplane is already tail heavy so adding a mechanism may add weight where you don’t want or need it.
Just my $.02
Just my $.02
Re: Adjustable seat
I did. I made a wood frame and attached a snowshoe weave with paracord. Steel pins in the seat frame allow several adjustment positions. Not much, but a little bit of recline. The frame is loose in the airplane - I will depend on seat belt system to keep me tied down. I took out some of the solid seat bottom. Even so, I have added some weight. I intend to cut out a bit of the solid back also to make access to the area behind seat for inspection.
Lawrence Harris, Tellico Plains, TN
Brian Amato
Re: Adjustable seat
I love that snow shoe weave. Light and looks "old timey"
Brian
Brian
