Clamping pressure
zippythehog
Clamping pressure
How can I measure clamping pressure for gluing gussets? AC43.13 recommends 125-150#/sq” for softwood. I couldn’t find any other recommendations for T88. I don’t want to use any clamp and hope for the best.
Re: Clamping pressure
Bonding pressure is mentioned in the white oak/teak section.
- Attachments
T-88_TDS.pdf- (25.14 KiB) Downloaded 218 times
zippythehog
Thank you.
How does one determine clamping pressure per square inch?
"minimal pressure -- just enough to ensure contact"
The pressure you quote is for resorcinol glue and doesn't apply to epoxy. Contact pressure is all that's required. Read the T88 instructions.
zippythehog
Thanks Larry and Richard. I see that now.
