status of current build
doug bryant
adding pics of current build. this will be cont powered, long fuse, cowings are also complete.
doug bryant
Re: status of current build
cont engine mount tac weld fixture.
It looks like you and I are at about the same stage. Where are you located? I'm in Cincinnati Ohio. Would be cool to get together.
doug bryant
im in wichita, ks. do u have pics?
doug bryant
very nice work!! can't wait to see it flying. this one i am building is my 7th. i still need to build some of the tail feathers.
Dan,
Beautiful work, and beautiful work,a ship!
What is the angled blue steel strap at the rear end of the plywood on the S’board side of the fuselage?
SEVENTH BUILD!
At some point I think you can no longer call it amateur built ha ha.
Could we get a photo montage of your life's work?
Tom, the blue fitting is just a U shaped strap for attaching a seat belt to.
Also, I was asked in a PM about the cable clamps on the center section cross bracing. These are temporary hardware store clamps, the airworthy versions will be swaged.
doug bryant
fuel tank complete and ready for filler neck. tank has stesrman type fuel gage.
Which epoxy resin did you use on the fuel tank? Do you plan to run auto gas?
Air Camper NX41CC, A75 power, avgas
doug bryant
polyester resin; non-alcohol fuels. i have built a few tanks like this with great results.
OK. It's the alcohol blended autofuels that can cause problems. Sounds like you're all over it!
doug bryant
used top from a dried can of pvc glue for filler neck and cap. plywood template is the master tool for all the top division work
doug bryant
doug bryant
these are the hardest parts to make on the entire airplane; but got them done
These are beautiful builds. It's almost a shame that we have to cover them to make them fly.
doug bryant
that is very true
doug bryant
completed tail feather fitting and rigging today. it was a productive day.
doug bryant
Congratulations!! It's a great feeling to be at the covering stage. Suddenly the light at the end of the tunnel seems much brighter.
doug bryant
all true! its a fun build!
doug bryant
Careful... I see you've got that plane inverted. Note that the Air Camper is Normal category and only good for negative 1.52 G ;o)
-Oscar Z.
-Oscar Z.
doug bryant
sure is easier to cover the bottom upside down though
doug bryant
Oh gosh Danoliver! That's beautiful! Don't ever cover it!
doug bryant
doug bryant
doug bryant
I think one of my former employers bought avionics from the same place you did! (The local photocopy-shop.)doug bryant wrote: Sat Feb 13, 2021 7:56 pm very nice work!! can't wait to see it flying. this one i am building is my 7th. i still need to build some of the tail feathers.
doug bryant
doug bryant
completed more on engine, covered ailerons, wing ready for cover.
